230 volt cable from control box to gantry
Can't help you on size but when you install the new one slide on a nylon sleeve over chafe points going all the way out and you will greatly extend the life off that dude. Check KR for sleeves they are cheap and will save your a$$
Old post, but I think mine is 12/5. IIRC You only need four, but the fifth conductor saved my bacon two weeks ago. It was a busy Sunday and the unit went down. I had low voltage on one leg. I had an extra wire and swapped wires. Back in business in 30 minutes instead of chasing a break in the wire for two hours.
