3 Way High Pressure Valve
Nuphoenix
I'm making my own underbody spray. Does anyone know of an affordable 3 way high pressure valve that I can use to divert pump output between the wand and the new underbody wand? Needs to be 3/8" and be able to handle 1200 psi normally.
IMO you're better off with two high pressure solenoids. DEMA 453P are good, there's some that are all SS but obviously more expensive. To simplify the wiring you could use one NO and one NC so you'd need only one selection input to switch.
I'm going to use the 453P's to start off with. I wasn't sure how they would hold up, so I was asking as a back up plan. Was going to wire one valve to the soap and rinse input and the other to the underbody input. Plan on just coming off the pump with a tee, the two vales, another tee for the weep and then two HP hoses out to the booms. Thinking of making a bracket to support all that weight hanging off the pump.
