3x foam Does NOT spew the Yellow
I know it's prolly a simple fix, but what's wrong when it will spew out Pink/Blue, but not Yellow?
rph9168
Carwashguy
Atlanta
You might want to check your dilution ratio for the yellow. For some reason yellow is one of the more difficult colors formulated into a detergent. In many cases the recommended dilution ratio is not the same as other colors or you may have to increase or decrease the dilution ratio to achieve the performance you are looking for.
Ok, so go up or down a tip size?
What if that does not solve it?
pcb
Leprechaun Car Wash
Dublin, Ga
If I remember correctly you have a LW 4000. Check that the injector isn't clogged. If it's ok, then the line should run out to the foam tube or the pod, whichever you have. You can take the line off the foamer for yellow and make sure it's getting that far. If it has the scrubbie pads to make it foam it could be clogged up and not letting the liquid through. My old LW had the scrub pads in the top center of the bridge and then tee'd out to each tube so if the pads are clogged up then nothing will come out of either side on that setup.
HCW
Kansas
At injectors, switch yellow line with either blue or pink and see if the problem persists. If it does check foot valve, tip, or dilution in yellow bucket as mentioned, if problem moves to different color, check injector or line problem. I had same issue and a clogged injector was the problem. Good luck and Merry Christmas!
BBE
USA
Just outo of curiosity, on the 3x foam manifold which port is yellow hooked up to? If you are looking at the pump stand head on, is it the furthest one to the left?
i'd troubleshoot by:
1. check chemical level in source ( 5 gal pail etc)
2. check foot valve
3. check level in mixing tank.
4. check filter screen in mixing tank outlet.
5. check for flow before chem solenoid / yellow
6. check flow after chem solenoid / yellow
