3x foam & JBS Glow Foam
1st issue: my triple foam is wet on 1 side, fine on the other. This out of a 3 pod, on LW4000. ADVICE?
€2nd question : anyone on here use the Glow Foam? If so, what's your thoughts? Will it really "glow in the dark"?
PEI
Danville, VA
1st issue: Check the foaming material in the pods.
2nd issue: I use their Glow Foam Polish and while I have never seen it glow in the dark, it probably would under a black light. JBS uses liquid colorant instead of a powder so you can turn up the color with little fear of staining a vehicle. There are limits and the cost per car would go up, but so would the show.
If it glows under a black light, let me know and my install them in a bay and charge extra for the show.
But, it doesn't seem like all 3 foamers, would simultaneously go out, on the same side...? I'm gonna check tomorrow.
mrfixit
Northern Illinios
Hey bud, I am now using jbs glow foam as well! The colors are bright and being able to go up in strength without staining is wonderful. I have used both Polish and wax. The bay is always lit so can't say if glows in dark.
Sounds like possibly an air line is kinked or most likely leaking for that side.. It should split off somewhere for each side and then split into 3 to feed each foamer. A leak on that side will reduce all three. No air no foam.
