RJMurph
So I have been with this new wash for a short while and I'm trying to figure out exactly what the issue is and why they retract there wraps as much as they do. Obviously there is not a strait answer to this problem and the only way to find out is to experiment.
However they retract the wraps on any vehicle with a side mounted antenna, like what would be on nearly all trucks and SUVs. And top retract when shark fin antenna above 6 inches. A bit to extensive IMO.
The tunnel layout is not sufficient enough to clean the tops and sides without these major components. It shows especially on white vehicles.
Equipment is all sonny's electricly driven, and my rough estimate would be wraps are running at 125 RPM, and I do not know about top. I will be looking further into this tomorrow. Also chain runs at 120 CPH.
They have the new sonny's cut neoglide with the folded rows down the whole brush. So each row of cloth is esencally doubled. This is different from what I have seen at the other washes I do maintenance for.
My ideas are that there could be too much brush marital causing the brush to pull on antennas and mirrors. But I don't know if the RPMS are too high. I have seen plenty of washes running very well with 130 RPMS.
I would like to see what you guys think!!
