ACW 4 Not Escrowing Washes
Mr. Clean
Central NY
When bay is occupied and next car purchases a wash, transaction completes but wash is not stored or initiated when bay empties. Is there a setting on the controller that inadvertently got deactivated or what should I be looking at?
TIA
MC
Keno
Have you tried calling hamilton? They have been good for support when we needed it. Escrow can be turned off too if it's cheating customers out of washes currently, which it sounds like it is.
JLanman
Champaign IL
Would be good to check the Cycle inhibit signal coming from the wash to the ACW4. Check the connections to ensure the signal is making it to the ACW.
Might also want to check the cycle synchronization switch:
SETTING THE CAR WASH CYCLE SYNCHRONIZATION SWITCH
The Car Wash Cycle Synchronization Switch is the silver toggle switch located on the Relay
Panel (Refer to Figure 3). The proper setting of this switch depends on the equipment used in
your car wash system. If the car wash equipment normally leaves the CYCLE/INHIBIT RELAY
de-energized while in stand-by, and then energizes the relay briefly when the customer exits
the bay, this switch should be set to PASSIVE. If the reverse occurs, where
the car wash equipment normally energizes the CYCLE/INHIBIT RELAY while in stand-by, then
de-energizes the relay briefly when the customer exits the bay, the switch should be set to
ACTIVE.
