ACW -Exact change Only
Whale of a Wash
5 Washes 36Bays 2Vectors
Fargo,ND
ACW went to Exact change only.Tried Spare hopper and clear out computer, and no difference, both hoppers coming up same display-Exact change only, any ideas.. Yes the metal sensors are completely covered with coins . The ACW does have CC's and Etowah Mars kit.
John
If you’ve changed out the Hoppers, you’ve pretty much ruled out the hoppers. The controller isn’t seeing the Hopper. You could have a bad wiring harness or Controller. Check the White wire with the Green tracer that goes to the Hopper from the controller.
Whale of a Wash
Fargo,ND
Thanks for the help i'll try it the hoppers seem to both work when i flip the switch in back, so to me they are working. I'll check the wires thanks
John
