acw4
Original Controller won't recognize .25 and every thing else works fine
Had a old spare plugged that in .25 registers
But eventually get out of Service Hopper empty and can't reset error
Hopper clean full slugbuster good etch
Thinking boards not so much wiring
Cause one does one thing and other controller different error
Sounds like two bad controllers if one works fine except for not recognizing coins and the other works fine except for hopper error. A wiring problem would do the same thing on both controllers.
What version ACW controller are you using? Not all of the ACW 4 controllers are worth having repaired.
