Before buying an air dryer I did some homework. The refrigerated dryers dry the air to a 32? dewpoint. My air cylinders are right inside the
door and while the bay is heated to 40? they get some cold air that leaks thru the weatherstriping, plus gusts of cold air while the
door is open. This causes the air in the cylinder, line, and regulator to get below 32?. Consequently I bought a regenerative heatless air dryer which has a dried air dewpoint of -40?. This type of dryer has 2 towers that the air flows thru. The air flow alternates from one tower to the other. While one is drying the air the other is purging itself. Due to this method of drying the air it consumes about 2cfm of air in the process and runs non stop. So it is always consuming air and dries the air as it flows thru the dessicant chamber(s). That's why I only want it on when the
doors are operating - I don't see any point on having it run during the night (along with my compressor), or between washes on slow days. My only issue with moist air is in my
door air cylinders. I had a piston come unscrewed from the rod, and when I took the cylinder apart it had more than a cup of water
above the piston. I don't believe that the water above the piston can get exhausted thru the blowhole in the bottom. That would trap that water in there. My
doors are extremely slow and sticky when the temp is single digits or lower. I am busy during those times and have to get these
doors working right. I had a lot of discussions with the folks at Twin Tower Engineering (the manufacturer) about sizing the dryer for my application and my compressor. They were very helpfull.
