AIR LIFT DOOR TROUBLE
slammindan
On my air lift door the front door when its up. And after they pay the door closes before they enter. What could be the problem with it. and it is a ryko.
From what I can gather from your post which is not very clear is your door is up and a customer pays then the door closes. Going off of that I would say your open and close signal wires need to be swapped. Your OPEN wire is going to your close relay and your CLOSE wire is going to your open relay. You need to switch the wires if that is the case.
