Having air pump issues / in particularly Flojet issues with Viton seals on Triple Foam applications.. A few things with these - I have them installed correctly with appropriate check valves etc..
- Air continually leaks from the vent on the pump
- In addition the product side seems to stall - and I need to purge the discharge at times re-install that discharge after I purge for the pump to pump again.
The performance of the pumps are bad - the cost isnt the issue - although they are not cheap - major concern is consistency for the customer - one week something works - next week it does not.. so - would appreciate any and all feedback - maybe Flojet is not the way to go?
