Eric H
I have a Airlift door motor that stopped working. I replaced another motor over the winter and struggled with it the whole time. Is there a way to more easily access the bolts that hold the motor to the gearbox? The 2 bolts on the side closer to the door nearly impossible to turn.
I know I can probably remove the entire motor and gearbox assembly but the shaft is probably seized in the gearbox. I couldn’t remove the keyway.
