David,
There are a couple of things on a LED-7 timer that will make it stay on constantly. Check ?Negative? wire on the horn to make it is not grounded, this is the ?blue wire from pin #4. It could also be a burned out the horn transistor inside the timer. This can happen if the Orange wire from pin #5 goes to ground, there is 12DC to this wire all the time. If this is the case you?ll need to send it in for repair. If the horn is on constantly only during the last minute of the cycle then you need to reprogram the timer, the LED-7 can be programmed to have the horn stay on constantly during the last minute. If you need a loaner let me know.
