pitzerwm
Conformity is absolutely necessary sometimes. For example, following traffic laws demands conformity or chaos reigns. Paying taxes requires conformity, and if you don't believe me, ask anyone whose creative deductions have resulted in substantial penalties -- or prison. And when your mother tells you to shape up, I would recommend conforming.
But conformity will not provide a creative solution to a problem. That usually calls for a different approach from what has been tried before, or a variation on the theme. Free thinkers are often dismissed as goofballs -- until their ideas have smashing success.
Train your brain to look at all the possibilities, not just those that are tried and true (or tried and failed.) To do that, you cannot think the way you've always thought. Try these strategies:
Look at the whole picture. It's easy to look for the simplest solution, but will that really solve your problem or just patch it up for the time being? Is this problem the result of following all the old rules instead of re-examining your practices for improvement?
Put yourself in another time. How would you have solved the problem 10 years ago? How about 10 years from now? Would you have the same choices available, or would you have to start over? Do you have all the tools/knowledge/staff you need?
Reverse the situation. What would a reasonable person do in your situation? What is the opposite strategy? You might gain a fresh perspective by considering the alternatives.
Bridge the gap. Think about where you are now, and where you need to be. How many steps are missing? Can you solve the problem with fewer steps, or are you so far from a solution that starting over is a real option?
Write down your thoughts. Spend a few minutes brainstorming all by yourself, and be sure to write down your ideas. Brainstorming means letting your imagination go, so nothing is out of bounds. Some ideas will be useless. Others might hold some promise. But the main point of this exercise is conditioning your brain to leave your comfort zone.
Speak up! Don't hide your ideas, fearing that you'll become the office joke. Your idea may not be completely viable, but you might spark others to find solutions.
