Auto Fault Start Wheel Well Fault won't clear from JO Box
acecarwash
Marble Falls
Does anyone have a solution to this problem. I've powered down the system several times and the fault message won't clear. I have a virtual treadle so this one has me stumped. Thank you.
lag
Middle of Iowa
The "stop" eyes are blocked. More then likely a faulty sensor, other possibilities.... Bad cable, lose cable, bad connection lose wire back to JO. Been a while since we had any VTs, but when we did it was usually one of the sensors on wall.
acecarwash
Marble Falls
Yep...it was a faulty sensor. Replaced both the entry and exit as they were very clouded. It now works like a charm...Thank you lag!
