Basic cold H2O set-up no soap?
gerijjj
alaska
I am looking for something as basic as I can get that has pressure and is coin operated. This would be used at my RV park to rinse saltwater off of boats. I have tried charging for it by having people come in and pay, they don't, the just use the fish cleaning hose and ignore the sign. I think if I had coin op in another location I could stop this use.
So I am looking for a very basic system, the water is going on the ground so no soap or anything, they just want to get the saltwater off anyway. Any ideas???
Kevin Reilly
self serve carwashes
Stockton, CA
You might check out kleen-ritecorp.com and I'm sure they can help you with what you are looking for.
All you need is a pump, a motor, a stand to mount them on and a solenoid to supply it with water. Electrical controls would be a motor starter and a timer/coin acceptor to start it.
frside1
memphis, tn
i have a monorail car wash system in a box . stainless steel cabinet i with timer and coin vault. it also has foam brush built , but you would not have to use it. or the high pressure soap. it is used but in great condition, just sitting on my shelf.
gerijjj
alaska
MEP001- I know that may sound simple to you guys, but I had all I could do to replace the coin box on one of my showers. I used to consider myself to having mechanical inclinations, not anymore!
gerijjj
alaska
frside1- I would like to hear more about this, weight is a real issue, I live in Alaska and as you all know shipping is a real bear everywhere now. My email is gerijjj@yahoo.com
frside1
memphis, tn
i will try and get pictures of unit and weight. although i know it is quite heavy. all stainless steel construction on outer skin. it is heated though.
jcollins
......If your familiar with the coinbox for your showers, just use one of them. Use the coin acceptor and timer to control a solenoid installed in the plumbing feeding the fish cleaning hose (if that's the hose your wanting them to pay for).
