Bay 2 stays on go, after it timeouts (D/H meterbox). Advice?
Punched in my code to wash down bay 2. Wen it timed put, the go rinse stayed on. I go in, turn off breaker, turn back on & its ok. So I try it again, & stayed on after it timed put again
Look inside & contactor is stuck on. I punch reset, & it goes off. Tried it again, same problem, hit reset button again & it shuts off.
Ideas, Advice? It's a D/H pushbutton w/ new touchselect pad.
Could it be bad timer, or bad contactor or What?
Pressing the reset button is killing the 24v power and resetting the washdown, same as killing the breaker, so it's not the contactor.
The timer isn't what turns on the pump on washdown, so it's not the timer.
It's probably your touchpad control board.
I actually put a brand new touchpad in in, 6 weeks ago. Been wprkingnperfect til yesterday! POLLEN SEASON hits, big money coming, & BAM!
SOOOO frustrating, as I have to be at work ALL day , then coach baseball practice/games all evening!
Isn't the touchpad separate from the control board?
Swapped doors, problem went with it. So, put door back on, & someone told me to call Keith Dilling (of Dilling / Harris). He had me reprogram it, & 'voila . Works perfect now. Was such an EASY fix. I wasted time, money & stress over nearly nothing!
I do appreciate advice you guys have. If anyone has D/H doors let this be a lesson...
