Hello! I have two spare Belanger SN 950 sonars for the Vector / They come with a magnet. How do I change the operating mode? I applied this magnet as written in the instructions, they do not respond, I ask for help
When you connect the sonar is there power? If there is then the magnet is in the wrong spot it's on the short step on the side play with it slow watch the light.
[QUOTE = "Flex-Wand, сообщение: 150510, участник: 9557"]
При подключении эхолота есть питание? Если есть, то магнит находится не в том месте, он на короткой ступеньке сбоку, играйте с ним медленно, наблюдайте за светом.
[/ QUOTE]Thank you
Thank you all for the answers. I managed to change the operating mode to option 5 according to the instructions, but my vector does not see this sonar until 2009. Maybe someone has faced such a problem
