garyinfla
Having a problem with a Belanger top wheel drive. The shaft that goes between the gearbox and the splined drive bearing has failed 3 times in 3 years. The shaft that the gearbox is mounted on strips. It looks like belanger replaced the hydraulic motor with a gearbox on this unit without beefing up the coupling. Anybody having or had a similar problem? Thanks.
