Equipment/wall cleaner should do the trick. We had the same problem last month. Stepped up from Simple Green, wheel cleaner then finally the wall cleaner. Complicating this was that we use reclaim to wet the foam and cloth. We hadn't kept up with regular buildup removal so it took a couple of passes at full strength to remove everything loosened up by previous passes.
