lighthousecarwash
Need some ideas from everyone. I'm renovating a site and just installed all new octaform panels on the walls. I started to drill the holes for the anchors for mat clamps and just don't like the result. When you start to tighten the anchors, it pulls the clamps into the panel too much, and if you drilled a little crooked, then it looks even worse. My thought was that someone needs to create a stainless plate with studs already installed that you could just bolt all the clamps on and then hang the whole plate on the wall. It would be less anchors, and easier to replace the clamps when they break. I'm sure I can have somebody fabricate it but wanted to see if there were any better solutions out there or if any manufacturers actually make something similar.
Lighthouse
Lighthouse
