Depends on what you're doing with it. For your wash, 3/8" would be plenty. If it's for your detail shop and you'll have lots of tools drawing from it, you might need 1/2".Waxman said:What size pvc?
If it's for your wash, a threaded fitting glued in should be sufficient. If it's for your detail shop, you'd probably want to use a piece of metal pipe clamped securely to the wall so you won't have people pulling and breaking off the PVC fitting while they work.Waxman said:How do you make the joint from pvc to an air coupling etc.? I'm not that smart...
1/2" Sch 40 (White) PVC pipe is rated to something like 500 PSI working pressure. Sch 80 (Gray) is stronger and would probably even look better as an install.Waxman said:So we are clear, you're talking about the grey colored pvc? I know they also make black and white.
