- Joined
- Aug 31, 2007
- Messages
- 6,373
- Reaction score
- 943
- Points
- 113
Blast N Vac
Got an e-mail today from Coleman re a Blast N Vac.
Seems it's a Vac that blows as well as sucks. They advertise the blower to blow away dirt and moisture.
their unit includes a seperate motor for Blowing since it specs out 2 Vac Motors and one blower motor. Did not see a link to a video so I have no idea what type of hose etc. is used for Blowing.
Got me to thinking about a retrofit or some way to use the vac exhaust as the blower.
Most vac motors don't have the tube type outlet so you would need some sort of shroud covering the motors, but if you used the existing motors how clean would the air be? Would restricting the exhaust shorten motor life?
Could you somehow try to mount a blower motor with a shroud under the dome and use a selector switch as a rerofit?
Any thoughts?
Any thoughts?
