partonken
I have a boiler with a vent pipe going straight up out the roof. Every time it rains I get water on the boiler and worse inside the boiler. I have tarred the edges around the flanges on the roof and the whole assembly looks water tight. There is a skirt that goes around the main vent , im wondering if I should use a high temp sealant to seal it. if you look from in the rafters you can see light through this round crack. Any ideas. thanks
