No, and I believe that if the boom is set properly you don't need them. When you hang up the gun, it should swing neatly against the wall, and the hose shouldn't drag the ground keeping it from moving itself out of the way. Other than idiots leaving the gun on their trailer or stuck in the stake hole in their bed, I've had almost no broken wands or boom damage. The breakaways would only increase maintenance for me because they'd get broken by rough handling that the wand can take without damage.
