Daily capture rate is ratio of wash volume to traffic count divided by activity. Here, activity is 365 days because you want daily rate.
Volume = 60,000 washes, Traffic = 30,000
Capture rate = (60,000 / 30,000) / 365 = 0.005936
Daily volume = 30,000 * 0.005936 = 178.0822 cars per day
Proof = 178.0822 * 365 = 60,000 washes
Estimate is produced by multiplying 178 and days open. Assume you are open 312 days.
Annual volume = 178 * 312 = 55,500 (rounded)
Here, know definition of count. For accuracy, use average annual daily traffic (AADT) because it includes traffic for year. Average daily traffic (ADT) is obtained from 3 days of 24-hour raw counts. ADT is not adjusted for seasonally or corrected for truck axles.
Capture rate and use have high degree of uncertainty. The reason is the rate is not based on cause and effect. It is not traffic counts that cause wash volume to fluctuate, people do.
Benchmark rates are published by ICA and Auto Laundry News and Professional Carwashing & Detailing magazines. These rates are obtained from survey responses.
These rates have high uncertainty because the calculation is done without information on position (corner, mid-block), access, visibility, geometry (median, traffic signal), demography or competition.
Studies have consistently shown daily capture is unbiased but it is not an accurate or reliable estimator of carwash volumes.
Other methods with more accuracy/confidence are analogue models, regression analysis and gravity and spatial models.
These methods involve increasing levels of data and expense (modeler) but give a more valid number to hang a hat on because estimators are based on cause and effect.
To put into perspective, using the models mentioned above is like a bookie that has extensive years of research in developing predictive models to handicap sports bets.
Using capture rate would be like tossing a
coin to predict winner and spread.
