Cat 310 plunger play
864real
South Carolina
How much should the plunger be able to move in and out? About to replace seals, getting water in oil, but also it is a little noisier that the others and noticed the in/out play. Is this normal amount and ok?
I checked one of my spare Cat 310 crankcases and it has no end play on the plungers. I'd have to say you need a new pump or at a minimum a new crankcase.
There should be no detectable play. That may run a while like that, but it will eventually throw a rod. You can probably find a used crankcase.
