chaz Active member Nov 9, 2016 #2 My CAT pumps have a sight class. I've been told oil to the mid point of the glass. Helps to have a flash light.
Waxman Super Moderator Nov 9, 2016 #3 I think mine has a red dot in the middle of the sight glass for oil level. I fill to that red dot. Yes I use a flashlight and mirror too.
T tdlconceptsllc Well-known member Nov 9, 2016 #4 4.2quarts or 134ozs is crankcase capacity from empty
MEP001 Well-known member Nov 9, 2016 #6 Fill to the middle of the red dot if the top of the pulley turns toward the head, fill to the top of the dot if it turns the other way.
