I have a 5cp2120 (same as 310) cat pump and whenever the pump is run or the weep kicks on instead of water coming out to the bay it runs out of the safety pop-off valve and straight to the floor. Does that mean that the safety pop off valve is defective, or is is a sign that something else is wrong? I went to buy one and in the description it said "Pop-Off valves are used as a back up to your regulator or unloader. They are designed to protect your pump if the regulator or unloader fails"
Does that mean that possibly my regulator or unloader failed? What is the best way to test what might be wrong?
I just shut the bay off for now, but need to get it repaired before it gets cold again as it won't weep.
Thanks.
Thanks.
