Cat Pump Head Eating Valve 'O' rings
bigleo48
All,
I have a cat pump 5cp2120w that is eating valve 'O' rings daily. The valve sleeve seems to be scratched. I changed the pump, but is there some way I can fix the old one's scratches...or is it junk!
BigLeo
It's probably eroded - the original 5CP2120W has a lifetime warranty and will be replaced by Cat. If there's an R stamped on one of the humps on the manifold, it's been replaced already and won't be warrantied.
www.dynajet.com or Vilco Supply in Tennessee can machine out the head and press in a stainless steel seat to repair it. I've been told they do the packing and valve areas, which in theory would be a permanent repair and the manifold will never wash out again.
bigleo48
Great info as usual! Thanks all...I'll get her fixed.
Big Leo
Bigleo,
I believe the Cat 5CP pump has a lifetime warranty. I think I'd contact my distributor and see about getting a warranty exchange before I spent any money on getting repaired. I'll check with my guys.
bigleo48
Just got a rma from Cat...I'll ship them the old, they'll ship me a new one.
Thanks again for all the good posts!
BigLeo
Only the original manifold on the 5CP models ending in W have a lifetime warranty. None of the other parts are covered.
Bigleo, you'll want to remove everything from the head before you send it, because you won't get it back from Cat. You'll receive only a bare manifold.
cleaning up mud said:
so is cat still warranting these heads?
Why wouldn't they? It's a lifetime warranty.
