Changing tubing through pump on IVS fragrance/vac.
APW
South
Can someone tell me the easiest way to replace the short piece of #16 tubing that goes through the pump on my IVS? The old one was brittle and broke off in the pump.
If the pump is the same as in the Fragramatics, you just remove the four screws and the cover.
Same basic thing, take off the wing nuts and slide the pumping units off the shaft.
APW
South
Do you know where I can get the tubing and is it a special kind?
It is a special tubing - either call IVS or Google peristaltic pump tubing. It needs to be the same OD and ID that's in it now.
