More about backflow of high-pressure into the low-pressure lines. When I was a tech, we had a customer with a new wash that got a bad batch of check valves. About once a week one would stick open temporarily and would blow a line off a low-pressure pump or at the tank feeding it (There was a check valve at the tank), or would crater the pump. The reason there was so much damage was because there was a separate check valve for each line rather than combining all the LP functions on one check valve. Another "tech's" solution was to add a check valve to the bottom of each stack of solenoids. This only changed the problem - now it would either blow the tubing or it would trap too much pressure in the manifold and none of the solenoids could open. The customer was no help to diagnose because besides being a 70-year-old woman, the gauges were pegged on the high side of the stop, and all she could tell anyone was that it wasn't working and the gauge "read zero." She finally called me directly, almost in tears out of frustration, and I replaced the three check valves with one of a different brand, which solved the problem.
