Clear Coat & Wax rotary switch interlock
Mister_Sharky
Recently switched from SwipeNClean to Cryptopay utilizing the rotary knob instead of the PBC controller. Does any one know how to wire the clear coat in for low pressure? Formerly the PBC controlled motor starter, aux 1 & wax. The motor starter I have jumped to my pump at the rotary switch along PreSoak, soap, rinse, wax on the first stack. Wax is jumped at the terminal strip to clear coat. PreSoak is jumped to Aux 1 which is our low pressure solenoid at the pump. If I wire clear coat to Aux 1 then both clear coat and wax come out low pressure. If I remove the jump between wax and clear coat ill get warm low pressure water and not low pressure clear coat. Both use the same chemical. One is low the other is high pressure. Any idea on how to separate the two pressures yet use the same chemical?
