Clear Curly Hose
Does anybody use the clear curley hose in an outside bay? How long will it last in direct sunlight? I have 3/8 curley hoses in-bay and they have lasted over 3 years with no issues. I am planning on taking the Pre-soak off the HP gun and giving it a gun of its own. Just haven't decided on the best hose to use. Standard 3/8 air hose lasts about 2 years outside on the FB before the UV gets to it. Just wondering about the clear curley hose with pre-soak running through it.
JGinther
Zip-tie engineer
Loveland, CO
Usually black colored plastics are the UV resistant ones. Look into the what the hose is made of... I doubt the clear would last.
I doubt it will either, but it depends on what it is. Nylon will last much longer than polypropylene, for example.
TurboJet
Have had the clear curly hose for tri-foam wax gun for about 5 or 6 years. Most are just now starting to become more yellow and brittle. However, less sun up here in the northwest, and air not dry. I'm happy with the life I have gotten out of these.
My braided HP hoses are the ones that I can't get any life out of due to cracking near the guns. Protectors help somewhat.
I've had good luck with the curly hoses on my tri-foam guns, but they are inside the bays. Are any of yours outside in direct sunlight? My truck/semi bay is completely uncovered and gets about 10 hrs a day of direct sunlight. This is the bay that I'm concerned on what type of hose to use. It will have a boom of its own, maybe I should use 1/4" HP hose and be done with it....
TurboJet
I do not have roll down doors. Ceiling/canopy height is 13 feet. So fairly open and the hoses are in contact with direct sunlight. In fact two of my end bays are covered with a canopy but only one wall, o these bays and curly hose get direct sunlight in morning and afternoon.
wash4me
Kansas City
You could extend life by rotating the hoses either by inverting them or switching hoses to a different bay.
MudMoney
Montana
I tried a clear curly hose in my outside truck bay ,it lasted one season.My truck bay is only open 6 months a year due to it being Montana.I use single braid wire hose and the only issues are when it gets hooked by a tall stack.
