Cleveland Float Valves
Tpoppa
Are there any common failure points on the Cleveland Float Valves other than the diaphragm? I've had 2 fail, 1 I replaced the other I attempted to rebuild. The rebuilt one won't completely shut off.
Are there any tricks to rebuilding them?
jimbeaux
Tpoppa, are these the models that have the float that rides up and down on a rail, similar to a toilet float valve?
jimbeaux
Tpoppa, there is a small diaphragm on the outlet side of the valve where the float operates. Also, make sure the diaphragms are facing the right way & not installed backwards.
