Even a couple small $20-25 infrared heater available at walmart will be beneficial and help keep the equipment room above freezing if in a pinch.Our carwash is in middle Georgia and we are supposed to get down to 18 degrees on Wednesday and several days in the 20's. My biggest concern is the touchless Water Wizard 2.0 It has track heat and has a blow out system, but it will only run if the wash has been used. Don't know if there is a way to make it blow out all the time during cold weather. We don't have doors on the tunnel. We also have 5 self serve bays with weep on the high pressure wand, but not on the anything else. No heat in the equipment room either. Any suggestions would be greatly appreciated.
How did u pump windshield washer fluid in the system?I shut down my car wash last night. Pulled the guns, foam brush handles, blew out the water, pumped windshield washer fluid into the systems and came home. I'll reopen on Tuesday when it warms up. We don't have floor heat, doors here in Western Washington. Right now it's 19 deg.
Thank you!The easiest way is to use a flojet pump and build the appropriate fittings to flush the lines. You can also use it to pump the tank out if you don't have a easy way to drain. Any self priming air or electric powered small pump that will produce about 20 psi or more of pressure should work OK.
For high pressure (and low pressure functions that weep)- If your weep systems feeds 1/4" poly hose feeding the pump that can potentially be a good entry point in the system.
For low pressure functions it's often just simpler to pump the regular product out of the tank and put the windshield washer fluid in the system and run the functions.
I have one Normally open solenoid valve that controls the weep system. I front of the normally open solenoid valve I have a ball valve, I use the ball valve to turn off the water to the weep system in the summer, when I need to winterize, close the car wash or when I need to do maintenance on the weep system. Downstream of the normally open solenoid valve I have a “T” with a 1/4” ball valve on the down leg of the “T”. When I need to shut down the car wash I connect a air hose to the ball valve on the “T” and blow out the weep system, connect a Flo-jet to the “T” pump in windshield washer fluid into the weep system. I put together a car wash shut down kit that I keep ready to go in a 5 gallon bucket. In that bucket I have a old Flo-Jet pump, hoses and fittings to connect the pump to ball valve on the “T” and a air hose that will reach from the air compressor to the “T”. I keep everything I need in that bucket with the lid on it so I can grab it in a hurry and be done with it. I also keep 5 gallons of -30 windshield washer fluid on hand, it’s sometimes hard to find, I bought it this year in September at Wal-Mart.How did u pump windshield washer fluid in the system?
