Coleman Hanna Power Pack Solenoid Rebuild Kit?
Yeaux
Having an issue with a solenoid valve on the low pressure foam brush manifold. When the foam brush is turned off the air solenoid for that bay won't completely seat causing the product in the line to be pushed out. If you tap the solenoid you can hear it close. I have traced down the company that provides these solenoid to Coleman Hanna, but it is not clear on what kit to purchase to rebuild it. Would someone have a part number for the rebuild kit?
Rfreeman
Ft. Worth
Unscrew the black cap. Remove the coil...using I think a 13 mm deep socket remove the stem a d inspect the plunger for any trash or corrosion. Also inspect the manifold where you removed it from. You might not need a new kit just clean it our.
Otherwise KR sells them don't have the part# handy at the moment
Yeaux
Appreciate the info! Will check this out tomorrow.
