Once again, I am replacing the hose on my Coleman shampoo/vac combo unit. I am using flex hose this time (the same hose used on oscillators on their water wizards). Problem is that the old hose is gaulded where it connects to handle. I tried heat and ruined the switch. Now I am trying to rebuild from another old hose assembly I have. Has anyone converted or tried a hose assembly form another mfg.? The design on the coleman hose is terrible. They weld the plate the brush is attached to after they install the switch, so if the switch goes bad you can't get it out to replace it. If I can buy an assemble from another manufacturer and get it to work I am going to do it. It is simply two small poly hoses and two 24v wires that are attached to the switch in the handle.
