colored low ph pre soak
wood
hey everybody:
this is the time of year where i go from high ph to low ph in my cloth system with high press assist.
i was wanting to try a colored presoak/soap product. anybody have a recommendation? i see some guys use a colored conditioner at the entrance which also is the same product many use in a foam wax application. how is that as a cleaner at the entrance, and how does it setup for the dry stage?
i think it makes more sense to achieve a color application with a low ph pre soak for midwest winter. any suggestion on products out there that are considered more of a cleaner as a low ph presoak with color?
thanks,
wood
hey everybody:
thanks,
wood
Get some dye and make your own.......
Been using KR Low PH conditioner in the pre soak last few months. Like it a lot.Also smells good and has color. Also use it in the water feeds to the cloth. Helps with water shedding for drying.
