one of combo vac/shampoo has no power to the unit. i checked the fuse and relay coil (rectangular), relay 24v Mercury it seem to be ok. The only thing left is the pump, air compressor and transformer. I do know that the last setting on the timer was on shampoo when it went out because i switch it out to another vac/shampoo it automatically switch on to shampoo. which is likely to be the problem? or is it something else? cause right now timer wont even power up.
