Correct Fuse?
MudMoney
Montana
What is the correct fuse to use on vacuum with 2 1.5 hp motors? What is the difference between an ABC-20 amp and a MDA-20 amp slo blow fuse? What are the common uses for slo blow fuses? Thank you.
I use a MDL-10 for each motor, or a MDL-20 if one fuse for both. They are slow-blow fuses, so they won't pop under the start-up load
The Doyle vacs had ABC-20 ceramic fuses on each motor, and within three months every one had blown for no apparent reason. They are electronics fuses - I don't know if they're a delay fuse, but obviously not up to the task.
In an emergency I've used a standard 20-amp automotive fuses, and they'll still blow before something burns up, but they usually melt under the metal cap just from the heat of normal draw from the motor running.
MudMoney
Montana
Thanks for your input. I will look into mercury relays.
