Plow Guy
My IR ARO went out this weekend. I would like to generate the quality of foam from my high pressure wand that you get from a low pressure gun. This way I can eliminate the extra boom gun and plumbing. I looked into this three years ago, I was told you can not generate great foam through the high pressure tip.My question is can I use a foam generator before mt check valve at my bay boom manifold thus creating a better foam from my boom down for a better presentation. If so will a Flojet create enough pressure or will I need to go to a Procon. Thankyou for your help.
