ted mcmeekin
Fast and Clean
- Joined
- Aug 30, 2007
- Messages
- 412
- Reaction score
- 1
- Points
- 16
We have a Mark VII fluid module for our SS which houses the hot and cold water holding tanks. Recently while isolating a float valve on the hot tank we drained tank and with no bays in service the cold water level dropped also but at a much lower rate. The only cross connect I can think of is through the 3 way valves for each bay which select either hot or cold rinse. I wonder if one of those is leaking by. Any other ideas or tips on cross over points and determining which valve is may be leaking? The rinse on all bays is cold--ie no noticeable mix with hot water.
Thanks,
Ted
Thanks,
Ted
