Dan-Ark
In the process of trying to solve the blow down air pressure backing up into the presoak tank, I discovered a 1/4 plastic tube wth a valve in it running from a T fitting before to a t fitting after the presoak solenoid. there was a check valve on the tire cleaner solenoid which I replaced thinking it was the source of the blow down air.
Can anyone help me out with understanding the reason for the tube/valve?
thanks.
thanks.
