D&S Bay Timer
i have a self serve bay from D&S. Normally when you put the $ in the selections will have a blinking button. Once you push the selection the light is solid. When you put $ in now and push the selection the buttons remain blinking and won’t come on. I opened the cabinet and checked the fuse and it was blown. Put in a new fuse but still doesn’t work. Any thoughts?
When I went back he next day the low pressure selections were working. That gave me enough info to look at the motor. It looks like the contactor to the motor was fried. I will follow up once I get it put on.
Put new contactor on and new relay will only work on bypass with key took new relay off put old relay back on would work with quarters so times then quit anybody have suggestions thanks
