Do we really need a foam gun?
JustClean
all over the place
Hi guys,
I was wondering if I could easily change my boring HP wax in the bay to make a greater show without installing a separate foam gun?
Is there a foam wax chemical out there that would make a great foamy show out of a normal gun?
Cheers
Justclean
You won't get the same foam from the HP gun that you can get from a separate one with a large tip, but look at Earl Weiss' video. That amount of foam and chemical would probably work fine for foaming wax.
[video=youtube;KlRMAQnwIPw]https://www.youtube.com/watch?v=KlRMAQnwIPw[/video]
JustClean
all over the place
Hey, thanks for the video. My low pressure wheel cleaner is very similar to this. I just thought maybe a "thick" wax would do the trick with my high pressure :)
I don't think you'll get any sort of result like that with high-pressure due to the volume of water needed to mix with it.
