stampedecarwash
Hello one of the exit doors open when you pish the open button but it wont close when you push the close button. It stops when you keep pressing the stop button while opening but it will keep opening if you let it go. The only way to bring the door down isto disengage the motor and manually bring the door down. Ive changed the eye sensors, loop sensor and also relays and still same issue.
