Double Bond question
briteauto
I am considering adding Double Bond to my top wash package. I currently do not use any Simoniz products, therefore I am not working with a Simoniz salesman so I thought I would ask this on the forum
Can you apply this through a standard arch, or does it need to be foamed?
Can this be used as the sole ccp (providing I get a good enough break to dry) or are you still using a drying agent or other ccp?
I have heard the beading can last a while, but does this product produce a visible shine at all?
I assume this is MSO free, is that correct?
Is this product scented or colored?
Thanks in advance for the responses.
Mike
tampaam1
Tampa, FL
Yes, this is applied through a standard arch. You will still need to use a drying agent as double bond does not act as a drying agent. It does produce a slight shine at application, and it does last for a good while. I do believe you are right about mso, but not entirely sure. There really is no color, and no real scent when applied to the car, although it does have a scent all it's own.
