'Drive In"
This is weird. I have a WW 1.0 and my "enter now' sign and "drive in" sign on the 10 position sign are lit up. It is not just the lights though. If you stand on the tredle the wash will begin. It is as though a wash as been selected.
I have tried turning off the Unitec paystation completely, but problem remains. I even went to Red Lion and turned off Pay station by selecting "no" on Unitec Cashier choice.
If you hit the reset button on control panel, it will turn relay off but comes right back on.
I know I had a water leak in the control panel when rained in roof. Anyone have any ideas as to why the wash is stuck in this mode?
Should I disconnect all of my cycle buttons on control panel to see if one of the buttons is bad?
look at the cycle buttons on the control panel door, we had a metal connector short between the two contacts and kept alarming the one cycle. make sure there is nothing touching the switches when the door is shut, the back side of the switches are not covered and can easily be reset.
Just had this happen to us. I told my attendant that I rembered reading something about it on the forum. And bam---there it is. A little wiggling on the switches, and I found which one it was and disconnected it for now.
Thanks forum members!!
