Dryer nozzle positioning
sparkey
I was wondering what you have found to be the optimum dryer nozzle position to dry a vehicle. I am only interested in the producers across the top specifically the outer nozzles as I don't have producers down the sides of the vehicle. Do you find that nozzles farther out on the sides of the vehicle angled in slightly are better, or nozzles closer together pointing straight down over the sides of the vehicle work better?
I have found that the best configuration is if you can make the blowers form a V to push the water to the side. If that is not possible any configuration that tends to force the water off to the side is better than pushing it straight back. As far as the sides go gravity should do most of the work and the more water pushed to the side the more that gravity removes.
